Πρωτη αποδεδειγμενη διαιρεση με το 0.
Posted: Fri Apr 01, 2011 2:16 am
by Adamaklas
Παρακατω θα δειτε τις αποδειξεις και το βιντεο!
In mathematics, division by zero is a term used if the divisor (denominator) is zero. Such a division can be formally expressed as a / 0 where a is the dividend (numerator). Whether this expression can be assigned a well-defined value depends upon the mathematical setting. In ordinary (real number) arithmetic, the expression has no meaning, as there is no number which, multiplied by 0, gives a (a≠0).
In computer programming, an attempt to divide by zero may, depending on the programming language and the type of number being divided by zero, generate an exception, generate an error message, crash the program being executed, generate either positive or negative infinity, or could result in a special not-a-number value (see below).
Historically, one of the earliest recorded references to the mathematical impossibility of assigning a value to a / 0 is contained in George Berkeley's criticism of infinitesimal calculus in The Analyst; see Ghosts of departed quantities.
Υ.Γ
Δεν ξερω ΠΑΛΙ τι με επιασε !Μετα το περας της ημερας μπορειτε κυριοι μοντερεϊτορς (Moderators) να διαγραψετε τα δυο ηλιθια ποστ μ!
Re: Πρωτη αποδεδειγμενη διαιρεση με το 0.
Posted: Fri Apr 01, 2011 8:21 pm
by Irishman
αυτό μόνο ο Ομπράντοβιτς μπορεί να το καταφέρει.
Posted: Fri Apr 01, 2011 9:53 pm
by Enositis
winterwood wrote:αυτό μόνο ο Ομπράντοβιτς μπορεί να το καταφέρει.
Θεος..
Με δασκαλο τον Chuck
