Πρωτη αποδεδειγμενη διαιρεση με το 0.
Παρακατω θα δειτε τις αποδειξεις και το βιντεο!
In mathematics, division by zero is a term used if the divisor (denominator) is zero. Such a division can be formally expressed as a / 0 where a is the dividend (numerator). Whether this expression can be assigned a well-defined value depends upon the mathematical setting. In ordinary (real number) arithmetic, the expression has no meaning, as there is no number which, multiplied by 0, gives a (a≠0).
In computer programming, an attempt to divide by zero may, depending on the programming language and the type of number being divided by zero, generate an exception, generate an error message, crash the program being executed, generate either positive or negative infinity, or could result in a special not-a-number value (see below).
Historically, one of the earliest recorded references to the mathematical impossibility of assigning a value to a / 0 is contained in George Berkeley's criticism of infinitesimal calculus in The Analyst; see Ghosts of departed quantities.
Υ.Γ
Δεν ξερω ΠΑΛΙ τι με επιασε !Μετα το περας της ημερας μπορειτε κυριοι μοντερεϊτορς (Moderators) να διαγραψετε τα δυο ηλιθια ποστ μ!
Irishman
Re: Πρωτη αποδεδειγμενη διαιρεση με το 0.
Post by Irishman »
αυτό μόνο ο Ομπράντοβιτς μπορεί να το καταφέρει.
By a lonely prison wall
I heard a young girl calling
For you stole Trevelyn's corn
winterwood wrote:αυτό μόνο ο Ομπράντοβιτς μπορεί να το καταφέρει.
Θεος..
Με δασκαλο τον Chuck
Return to “The Funny Section”
